Ac line adapter
84cutspreme
1,163
158
Trying to figure out which adapter i have to use to install 307 lines onto compressor from gm serpentine system 92 camaro style, anyone remember which one they used?
It looks like plain rubber on d/s and green one on p/s with longer spacer
I have the kit, came with serpentine setup, A/C delco n all
Then what exactly are you asking. It sounds like your asking for the stuff needed to hook lines to ac compressor. Thats what i gathered in other words the gasket/ seals and extender sleeve. Thats what the link is a kit with everything needed to hook 307 lines to you new compressor.
well the kit they sent me is just the adapters per say. I have all new seal kits laying around for this. The kit comes with 2 spacers and 3 washer style adapters. I was just trying to figure out what combination I need to use.
This is whats in the kit they sent with it: Looks like I need to use the 2 washers on the right and the spacer to the bottom left
I think i used the green on with the short sleeve on one side and the copper or gold colored one o the other side. The sleeve and green only go on one side the other side it you put it on will fall inside compressor.
