Oh, and make darn sure your compressor O-rings and front seal aren't leaking. Nothing worse than going through the motions of fixing all that junk only to find the O-rings on the cylinder sleeve and/or the front seal is leaking.
This is a VERY common problem with R4 compressors. Especially NOS or original GM ones. The o-rings just get old and start leaking. They're Buna-N, or NBR from the factory and really only made for R12 applications.
My recommendations:
You NEED a double lip seal on these R4s. Why they didn't put them in I'll never know. They only have a single lip seal or early models used a mechanical seal.
The set of body O-rings is Santech MT2119- Autozone sells these for about 9 bucks. They're the green HBNR type, which are better than the original rings and compatible with 134a or similar.
Double Lip Shaft seal- Santech SK-741N
Seal protector thimble is Mastercool 90484. If anyone attempts a seal replacement, you MUST use the protector. Kent Moore has a similar deal that GM techs used. No need for that. Too expensive normally.
My recommendations:
![www.ebay.com](https://cdn-0.gbodyforum.com/proxy.php?image=https%3A%2F%2Fi.ebayimg.com%2Fimages%2Fg%2FxEAAAOSwZ1tkp5ji%2Fs-l400.jpg&hash=7376cccd1f8d14fed88da226636432ff&return_error=1)
AC GM Compressor Lip Shaft Seal R4 V5 HD6 HR6 HR6HE DA6 HT6 A/C DOUBLE LIP 14MM | eBay
THIS 14mm DOUBLE LIP SHAFT SEAL KIT is considered an UPGRADE to the standard Single Lip Seal. only 1 14mm shaft seal kit. For 14mm Standard Shaft Size. can be used in A6 compressors and in early model R4 compressors replacing the regular "2 piece" type carbon seal.
www.ebay.com
![www.ebay.com](https://cdn-0.gbodyforum.com/proxy.php?image=https%3A%2F%2Fi.ebayimg.com%2Fimages%2Fg%2FMPwAAOSwLdlmfexk%2Fs-l400.jpg&hash=dfe5844c9b9c52e115f3fa82d52c5c08&return_error=1)
mastercool inc, 90484, gm seal protector. | eBay
Find many great new & used options and get the best deals for mastercool inc, 90484, gm seal protector. at the best online prices at eBay! Free shipping for many products!
www.ebay.com
