86Cutlass383SR said:Air shocks will raise the rear ride height. But that's not the best way to do it. If you need to raise the rear for tire clearance, you're relying on plastic lines to maintain pressure to keep from cutting the tires. Don't do it. It will also make the ride harsh and stress suspension parts.
A taller rear spring would be better, more realiable, and also cheaper than air shocks. Air shocks are meant for leveling the car when an added load is carried. Nothing more.
