regalman4925 said:take the front two channels and run one side positive to the positive on one speaker, then from the negative run it to the positive on the other speaker then run the negative to the second speaker negative. by doing this you will create a 8 ohm load running to the unit making it so it can work with out over loading your head unit. if you run 1 channel to 2 speakers doing pos to pos, neg to neg you are creating a 2 ohm load and you are going to over heat the head unit and likely blow the channels on the head unit.
