Aftermarket Pulleys
Riggs
Jan 21, 2009
74
Are there any available aftermarket pulleys for a 1986 Olds 442? Does BBK or anyone make them?
what motor is in it
why are you so set on aftermarket pulleys you money is better spent elsewhere
Cause my crank pulley is the wrong one and I need the proper 307 pulley and I figured if I'm going to get a new pulley I should get something with performance in mind. If not I'll just have to locate a stock 1986 442 pulley.
Why buy new? A used one is less than $10 at the junkyard. Besides, with the money you will spend on aftermarket pulleys, you could just buy a bigger engine.
