So i bought some guages for my monte,i plan on getting the 3 piller pod. my guages are temptuare, oil pressure, air and fuel ratio but how can i hook it up if i got no o2 sensors and have headers on ? any help would be greatly appreciated.
MrRabbit24 said:well i once road on a ford lightning and it had that guage ,each time he gave it gas it would go up and when he wouldnt it would stay yellow, than clime to green again thats basicly what i would like
WalkerTech said:Rabbit,
I am a Product Specialist with Walker Products, a manufacturer and worldwide distributor of oxygen sensors. If you want your AFR gauge to function properly, then I would follow FE3X Clone's suggestion of installing an O2 sensor in one of the header collectors. Use a mild steel bung (Walker # 90-164) and a heated sensor (Walker # 250-23000). This sensor has three wires, with the black wire connecting to the original sensor wire, one white going to a fused 12 v source, and another white going to the chassis ground. This sensor is moderately priced and your engine will benefit from its installation. Good luck.
