alternator wiring
str8muzick
19
deltona florida
i have a 83 pontiac gp sbc...i want to change form a si alt to cs alt...on regulator plug from car harness there are 2 wires red and brown on cs unit plug there are light pink which is marked on plug (f) and brown (L) which goes connected from factory harness i got the cs unit regulator plug from junkyard need help please
There are adapter harnesses you can order to plug in, but you can also get the plug for the CS alternator from a junkyard, wire a 10-ohm, 10-15w resistor, and connect that to the brown wire, you don't need the red wire.
