Just wondering if anyone has thoughts on this, I have a nice Griffin Aluminum rad in my 84 Cutlass that was put in 6 years ago when I put the car together. It was a few years old at that time, but anyways, it's never seen salt, had regular coolant changes, a couple years ago it started leaking intermittently. It took me a while to track down the leak as it usually occured only in colder weather, start and end of the driving season. Now it leaks all the time. I also had to replace the heater core last year cause it started leaking, even though it was only about 6 or 7 years old too. Both of these happened maybe a year after I accidentally overheated the engine by forgetting to switch on the electric fans.
The temp gauge was wrapped back around almost to 0 when I realized it (probably 280* plus). I turned the fans on and cranked the heat and popped the hood and let it idle until it was down to normal temperature. It never boiled over. The engine was completely unharmed even with I'm assuming the factory head gaskets from 1975-1976 ish. Do you think the overheat could have damaged an expensive aluminum rad and a heater core, but not cooked the 35 year old never rebuilt 350 Olds?
I'm finally pulling the rad this fall as soon as I park the car for winter, to take it and see if it can be repaired. It sure kept the engine nice and cool as long as I didn't forget the fans. This winter its getting a proper coolant temperature control for the rads too, so no need to lecture me on that 🙂
