I know this subject is beat to death here, and I have read countless threads on the subject. I wanted to get a personalized answer as I haven't come across a thread that really spoke to my situation.
I am not a wrencher, motorhead, gearhead whatever you want to call it. I recently picked up an 86 Cutlass with a 327/TH350. I am not afraid to mod or work on this Gbody, with that being said I have never restoed or modded a car in my life. I have taken in a sh*t ton of info since joining the site and I want to say thanks for that.
Now for the thousand dollar question "Which direction should I go with this rear end?"
The car will be strictly street and a cruiser with maybe a few Friday night test and tunes, it is our 3rd car and will need to be driven 1-2 days per week. The motor is cammed up nice and the TH350 was rebuilt, I was told the 327 was pushing 400HP but I am skeptical. I won't be adding any mods to the engine so a "beefed up" 7.5 may work fine. I want a posi rear however, I want to burn both tires, and I want it to hook nice on Friday nights. Maybe a LSD would work but honestly I don't know, I'm a friggin n00b. I do not want a spool, I had a gbody with a welded rear end and I assume a spool would be similar to that, I hated how that handled. I believe swapping an 8.5 presents the easiest project for my skill level assuming it doesnt need to be pulled apart and rebuilt in any way. I am also open to swapping out the carrier etc etc so I can get posi/LSD and a 3.42 into the 7.5. I believe the option of an aftermarket 9" (even the cheap one from Quick Perf) is a bit more investment than this car requires considering the output and the limited upgrades I have planned for it. I guess a third option is the 12 bolt mod/swap or even the 8.8 The problem with these 2 solutions is for 1, I have limited contacts, as far as a trusted shop in my area, and 2, doing the mods and swap myself are way beyond my skillset (I do not weld)
1. Is swapping out 7.5 for 8.5 "easier" than swapping the carrier/gear etc? Keep in mind my basic skills and basic garage (I honestly have no clue what a shim or crush sleeve looks like).
If the swap is the way to go, I would still be putting a 25+year old part(s) on this car, I assume there are preventative maintenance steps that need to be taken (bearings/seals/fluid?)
2. What parts/tools exactly would I need to turn this into a posi/LSD with 3.42? What car is a donor for the carrier? for the gear?
Is there anything I should be aware of or watch out for when contemplating and completing this project? Thanks for any help and answers you can give in this thread.
