I’m taking out my crummy dash. It’s all stripped of components and hardware that I know of. I got the steering column brace freed up. Is the top just glued in? I don’t want to break anything. Should i just keep wiggleing it out?
There’s 4 screws on top by the defrost, a couple at the bottom on the outsides and one in the middle below the radio.I’m taking out my crummy dash. It’s all stripped of components and hardware that I know of. I got the steering column brace freed up. Is the top just glued in? I don’t want to break anything. Should i just keep wiggleing it out?
I got the 3 10 mm. Nuts on the bottom.Success !! The 4 defrost screws were painted over. In the one pic, what is it? It is inside the dash in the area of the headlight switch. Is it just the buzzer? And can I omit it? The second one is obvious as to why I’m swapping. Thanx for the assistThere’s 4 screws on top by the defrost, a couple at the bottom on the outsides and one in the middle below the radio.
