Similar to the other recent threads about this, but enough different that I figure it deserves it's own thread. 1979 Grand Prix, 301 2bbl, all original, transmission rebuilt about 800 miles ago and brought in for the transmission follow-up about 50 or so miles ago.
Scenario:
Very hot day in Florida I get off work and go to start the car after sitting in the parking lot all day. 1st crank - it sounds rough and is a little weak. Not normal, but not necessarily "bad", and doesn't start. Not surprising as it's been all day and usually starts on the 2nd try anyway. 2nd crank, it has the same sound, and is still slightly weak, but starts right up as I was expecting. I left the lights on a couple weeks ago and had to get a jump, and one day last week it had a slow crank, so I was thinking on the way home, I probably need a new alternator (and likely battery). I drove home at highway speeds for about 10 minutes - it ran just fine the entire way, no issue at any stoplights, no issue at 70 mph, no issue at 40 mph. Ran exactly normal the entire drive home. When I got there, I turned it off and tried to start it again. Same thing as when I was at work. Slightly slow crank with a rough sound, but started. So I pull it into the garage and throw the charger on the battery to charge overnight. got up this morning and see the charger showing 100%. Hop in ready to go to work and it doesn't even crank. No clicking, no weak turn, no sound at all that I can hear with the window down. Headlights work, radio is on, horn works, interior lights are very bright. Nothing when I turn the key.
What I've tried so far:
I hooked up a small, cheap jump pack (display showed 85% charge on the pack itself) and it didn't change anything. Shifted it into Neutral and tried to start it, same thing, no sound, no crank, no anything. Shifted back to Park, let my foot off the brake, it rolled backwards about an inch, and I tried again. Same thing, no sound, no crank, no anything. So I pulled the battery, everything looks good, clean, etc. There are a couple very small spots on the positive contact point on the cable that have the tiniest bit of corrosion - was the red bolt the tiniest bit loose??? Could have been now that I look back on it, but I don't think so and it's been starting/running fine except the couple times I recently needed a jump after leaving something on. So I bring the battery for a load test and it's fully charged and cranking at the right amps (actually ever so slightly higher than rated).
Planned actions:
When I get home tonight I am planning on thoroughly cleaning the contacts (even though they look clean already), and ensure they are tight and give it another shot. I'm hopeful, but expecting no change. Tomorrow the plan is to visually check all the cables into and out of the starter, maybe give it a tap-tap with a hammer and try it again. If that doesn't work, I have a solenoid bypass switch that I'll hook up to see if it starts with that. I'm really hoping it will as I believe it is likely a bad starter and/or solenoid. However, I'm a little concerned about the "rough" sounding crank the last 3 times it did actually crank and I don't want to do any damage to the engine (if I haven't already). Would a bad starter and/or solenoid cause it to not do anything at all when the key is turned? I thought I would hear at least something, but no.
Questions:
Should I do anything else as a precaution before trying to start it again?
What else can I check if none of the above work?
Thanks in advance for any advice/info!!!
Scenario:
Planned actions:
Questions:
