I'm betting you don't have the brake light operative any longer either with the new gages. Which is a shame, because if you did, you'd likely see the slide valve went to the rear if you were able to bleed the fronts without issue and your brake light illuminate on the dash.
There IS a way to reset it manually, but it would require taking the rear line off the combo valve, tapping the flare seat with a 6-32 tap, then use a 6-32 screw and nut with a large washer and use it as a puller to yank out the seat and back section of the slider valve assembly. You can then use a screwdriver to push the shuttle valve forward. Yeah, a bit of work, but you could do it without disassembling EVERYTHING.
Check it out here.
www.musclecarresearch.com
Check it out here.
