No compression check yet- we stopped last night after discovering that the triggers (not stators as mentioned) are different. We have to put the old trigger and stator back on to get the flywheel on to do the compression check. I suppose that will be on this evening's agenda......
I'd like to be able to measure the outputs on those, but I need the FSM for values to look for. I plan on at least testing the coil leads to see if we're getting voltage and a pulse from the trigger assembly. I should be able to get something off the 2 cylinders that were firing, anyway.
I have read some nasty stuff about voltage spikes from the regulator, but that seemed to fry coils where the defective one tested identical to a known good one. This is all assuming it will fire with the old trigger assembly.
Man the parts are outrageous! ~$250 for the trigger, ~$3-400 for a stator, ~$300 for an ignition module
