I have an '86 Regal. Currently has a 350 sbc with edelbrock performer intake, headers, mild cam, and the dist. has been reworked for performance. The trans is a th200r4, and rear end gears are 3:42(non posi). Heres the problems: engine may have a spun bearing, and the trans is sick (apperently 200r4's are famous for breaking the stator, or the pump). But I have a th400 to put in but needs rebuilding, and a 350 block ( 350 block never bored over, 10% nickel so its the best block you can find, four bolt mains, and i've reworked the oil valley, drain hole and under the timing cover.). I also have a complete set of balanced domed pistons on gm rods, and 126 heads that should give around 9.2:1 comp., a HD gm crank, and a holley 3310 4bbl carb. I don't want to sell but we are expecting our 3rd kid soon and shes (the baby) more important so no time/funds to work on the car, and where I have it stored wants it moved. I had it painted winter of 03/04 its bright red (volkswagon color) with battle stripes (black) and a vinyl top. I repaired the frame by boxing in with 1/4" plate, but needs a body mount on the drivers side rear. If anyones interested will let everything go for $1500.00 obo. canadian. For pics see profile.
