Thank you for the breakdown of the visors. I should've been a little more specific. The mirrors aren't the illuminated type. which probably doesn't matter. They probably are assembled and removed the same way. I guess the mounting screws are situated behind the fabric. No exposed screws.There should be two screws under each of the clear lenses for the lights. How you get the lenses out without breaking them is unknown.
I don't ever remember paying that much to have my visors recovered. I think the last time was with my wagon visors. I supplied the material from my headliner and the woman at the shop charged like $40.00, which I thought was reasonable.I just brought a set to a local upholstery shop and paid $120 for the pair to redo them. I thought it was overpriced but I don't have the sewing machine or skill to do it at home. I think I had a set done 15 years ago and recall it was under $50 but that was a lady in a small town working out of her basement in ND vs a brick and mortar store in the big city.
It was a set of broken cardboard upholstered set I pulled out of the salvage yard that needed much of the board replaced. I supplied leftover material from when I did the headliner.
You need to be able to sew the hem to do them. My wife that sews blankets and baby stuff said her generic sewing machine can't easily do thick foam backed fabric as it will pull, so unless you have a HD sewing machine you probably can't do it at home. Glue isn't enough.
Brand new ones are $135, it's not worth doing them in many cases IMO
That's some rock solid info right there, thanks for sharing it!GM does everything as stupid as it can. When I did my wagon headliner I was lucky enough that my visors were in good shape.
When I did my Jeep Cherokee, the visors unsnapped apart. They unfolded like a wallet. The mirrors and lights were easily accessible. You removed the old material, glued the edge of the new headliner material onto a crevice on the inside, then they snapped back together. And guess what? The three screws that hold the visor to the body? They are the same as our GM pattern. Hint-hint.... And the spring they used is way better than GM's. The visor stays in place, unlike ours that droop.
View attachment 252142View attachment 252143
Mark,GM does everything as stupid as it can. When I did my wagon headliner I was lucky enough that my visors were in good shape.
