anyone riding on camaros rims?
I'm not sure which camaro these are from, but i like them on my car. They are 16x10 and only the front needed 3/4'' of spacing
these corvette wheels were between 8.5" to 9" wide...
they brought them upto 17" when they went 10" wide...
in either case, you will need to use 1" to 2" spacers, as the Corvettes had very large offsets
clean8485 said:
Don't know of a GM factory 16" X 10" rim. They're probably 16" X 8", unless they're aftermarket.
I do believe you're right they aren't x10 but theyre DEFINATELY bigger than 8''. I'll have to bust out the ol' measuring tape.
They're IROC rims and they are 8" wide. Rim width is measured from the inside of the bead to the other inside portion of the bead, so you can't truly measure them without having the tire off the rim.
Hi folks ,Im new here and speaking of Camaro wheels ,I was thinking about going with some 2010 Camaro wheels for my 1979 Malibu classic 2 door .I just wanna know if it's even possible .I saw some on a late model chevy truck and it looked good as hell .
The wheels on the wagon below were first used on Camaros, this set are actually Sonoma/S10 ZQ8 wheels...the first version of ZQ8 wheels.
9.5", unless they're ZR1 rears, which are 11" (the pictured wheel is not a ZR1 wheel)
I'm running IROC 16s and they need longer studs on the front for sure cause they will rub on your tie rod ends. Need longer studs on a 1/4 inch spacer.
