In the book put out by the late, great John Lingenfelter, he states that there is usually enough valve spring pressure to keep the roller tip from actually rolling. Unless they've already been changed, stock rocker studs are 3/8". If you've still got the stock rocker studs then these won't work. If you have to buy new studs to make them work then any $$$ saved will be spent on the new studs.
If you do still have the stock studs, check out Summits stock style long slot rockers (SUM-G6800) for 3/8" stud. $42.95 brand new. Doesn't state max lift but should be good for the XE268 cam if it's a flat tappet. Includes new ball and nuts :shock: With a cam that size, there really is no need for 7/16" rocker studs.
