Hello friends
I'm stuck with a problem baking my brain. I need some technical advice on this.
My 1978 Pontiac Lemans needs a new axle housing (it has a GM 7.5 10Bolt) for these reasons: rust, deterioration on all the mounting parts, and the impossibility to get a decent brake upgrade (drum to disc) as the axle flange is only a weird rectangle with 3 mounting holes.
I'd like to avoid buying a used one and refurbish it myself, so a newly manufactured by Moser Engineering sounds good as they come fully assembled with the brakes I actually want. Buuuut they don't have a direct bolt on, so custom housing is needed. They do offer an assembly option for a 78-87 G-Body (Grand National). Check here:
http://www.moserengineering.com/com.../12-bolt-built-to-order-rear-end-package.html
According to Wikipedia the 1978 Lemans was build on the A-Body, renamed to G-body in 1982 after the new front wheel driven body was introduced as A-Body. So basically, if my theory is right, the above mentioned assembly should be a direct fit, unless the G-Body had some changes in its suspension configuration over the years...
Can you give me any input or share your experiences you had on same/similar issues? That would be great!
