Replaced both rear axle seals since they were leaking a few drops after 1 year (replaced about 1 yr ago) while doing the rear disk brake swap. New one on the drvr's side is leaking again after only two weeks of installation (drop on the wheel) . I have run the car while on jack stands and never lowered it from the stands. These are National Seals, put in dry with no sealant on the surfaces, lubricated before installing axles, axle surface was not gouged and was smooth. Used a seal installer, checked the seal spring and it did not fall out! Any ideas? I hate pulling "C" clip axles.
