Just went and measured mine is 8”, not even the largest section is 12”. What does that mean now?Yes is it 12 inches tall or 8ish inches
I think I will do the 90 Caprice booster and master as a set like suggested. Both together from advanced are less than $140.
Like Turna said.
NEW MASTER CYLINDER OPTION
This master bolts right in no mods and actually works AC DELCO Master Cylinder Part # 89056529 or 18M974 (same master)
1.0" bore master cylinder
I do not recommend a step bore master cylinder which came on almost all 1982-1997 GM vehicles.
The 1990 B-Body vacuum booster is an upgrade along with the 1.0" bore master cylinder listed above.
Roger that. I have the stock prop valve in now and no brake drag on the rear, they spin free in the air. I will upgrade the master and see what happens. Thank you!Do NOT make a lot of changes at once. If you already have the rear disc setup on, just replace the master cylinder first and then sort out any issues that might come up (Low pedal, hard pedal, etc). These things might not come up, but you only want to rule out the few changes you made.
If you find that your rear pads are dragging on the rotor after the rear disc and new master cylinder swap, then replace the prop valve with a disc/disc version.
A LOT of people are still running the stock prop valve with rear disc brakes with no issues.
