I just ordered a set of Global West Negative Roll upper control arms for my 1985 Cutlass and plan on getting a set of B body spindles and calipers to go with them. I want to use the 1LE 3g Camaro 12" rotors up front as they are identical to B body pieces save for the bolt circle.I need to know which brake hoses to use-donor B body or G body? Also, which Master cylinder has the right volume to use with these calipers? I am also thinking about using a 8.5 rear from a turbo Regal or 442 and wonder if the larger disc brakes off a 4g F body will bolt to the axle flanges, and if so, which master should I use with this brake combo? Can I just gut the Prop valve and use an adjustable aftermarket one to set the brake bias?
