Backspacing
Backspacing means the space behind the mounting plate measured to the inside lip of your rim. If you’ve got that same 18 x 8 inch rim and it’s got a 3 inch backspace, that means there are 3 inches between the mounting plate and the back lip and there are 5 inches left on the front side.That makes these rims have a deeper dish than the same rim with zero offset and 4” backspacing would have.
Offset
Offset is either called negative or positive and it’s measured in millimeters with either a + or – symbol, meaning positive or negative offset. And you thought you’d never use the metric system in your life! Since the offset of a rim is always measured in millimeters it’s important to know this conversion = 25.4 millimeters is equal to 1 inch. Even if you need to use a calculator when checking out a set of rims, at least you’ll know what you’re getting into.
If you have a negative offset, that means the mounting plate is closer to the suspension side and further away from the outside of the rim, leaving you deeper dish rims,which typically makes them stick farther out from under the truck than your stock rims. A positive offset means the mounting plate is closer to the outside of the rim, leaving you a smaller lip (or almost none at all) with a larger space behind the rim which keeps more of the wheel under the truck
Here’s an example: With our same 18 x 8” wheel, if it has a 0 (zero) offset, then the back of the mounting plate is dead center in wheel. And dead center of an 8” wide wheel with 0 offset would mean the backspace is 4”.
If the offset of this wheel is +25, that means the mounting plate is 25 mm closer to the curb (about 1”), giving you a wheel that sticks under the truck more than one with
A wheel with 4" of backspace and Zero Offset will fit differently than a wheel with 4" of backspace and positive or negative offset. A wheel that may fit without hitting the frame with zero offset but if a wheel with 4" of backspacing and a positive offset may not fit!
Not all wheel backspacing is equal:
