I have a 26" drop-in Champion radiator with stock location inlets. I have a 454 bolted to stock SBC motor mounts with a Proform aluminum long-nose water pump (#68241). I am trying to connect the two.
I began by purchasing stock hoses for a Monte Carlo SS. The lower hose looks like it might work, if only it would fit over my water pump inlet. My water pump inlet is 1.75" as expected, and the hose has an ID of 1.75" at that end... but my pump has a huge lip that measures 2.0" in diameter... and this hose does not want to fit over it at all. Researching in this forum, somebody said to buy Dayco hose #70936; but as I look at that hose online, it seems to have the same 1.75" ID at the pump end. Does anybody have any other hose part numbers that might work for me?
At the other end of the radiator, the upper hose is way too long and isn't close to working. Again, I hear tell the Dayco #70548 is the ticket... but I don't have one of those yet so I don't know if it really will fit. Can anyone here confirm that for me?
Thank you in advance for any assistance you can provide.
