thats pretty much it, the motor mounts are the same and the frame mounts don't move, nobody makes a standard hedder for the BBC G-body so we're limited to very expensive Hooker Super-Comp's or slightly modifying early A or F-body hedders, you can always run cast manifolds, give it that factory appearance even though most people know the G-body nvr came with a Rat as a factory upgrade, thats ok... we have the technology
edit: tall valve covers will not fit with the single-diaphragm brake booster as it is larger in diameter than the dual-diaphragm booster
