okay guys... I have a feeling my engine is experiencing blow by,
I currently do not have a pcv valve setup, just a hose that goes to nowhere. I will be putting a pcv to the carb asap. There is smoke comming out from the hose. (I'm aware this is caused from crank case pressure)... but the smoke is continuous, and not in spurts.
I've read that a continuous flow of smoke is a definite case of blow-by... is this true?
my engine specs are as blow in my signature. The engine was built in 2005, and only driven a few times a year until 2008. In 2008 and 2009, I've driven it ALOT, to work and back everyday, and drag raced 2 or 3 times each year. I would say the engine is now around 10 - 12,000 kms.
if the engine was old and "warn-out", I would expect this sort of problem. However, 10k - 12k is not exactly "old" and "warn-out".
I have checked the oil, it is good but dark (not milky). There is no white exhaust or hints of headgasket problems. I've also checked the coolant, and besides being old, it seems clean and oil-free. And there is no dark or coloured exhaust smoke or signs of valve lash problems (they are closing properly). I will be doing a compression test this weekend to confirm.
any thoughts? videos to show exactly how much is too much, would be great!
