Blower running all the time
1bad79
1,023
893
Allendale mi
my 1979 cutlass heater motor runs all the time on low when the key is on even when the top lever is in the off position my issue is I can't seem to find a correct diagram with the relay that's mounted to the hvac box every one I have found just has the switch and resistor block but no relay does anyone have a factory manual with a diagram
They can share with me so I can fix this thanks
Do I just tried it out again it hasn't run in a few years and it worked as it should but about the third time it stuck on I unplugged the off screen- heat switch and the fan speed switch from the hvac controls and it's still running do I guess the relay is stuck on?
Here's a diagram. Straight from my Haynes Manual. Hope it helps.
It may also be that your blower motor is bad. I think mine is bad too, as it screeches and it only works on one setting and only blows through the defrost vents.
So I unplugged the thermal switch up under the dash and now it functions the way I want it to, I had no relelection of any of my g body's doing that it always blew heat when the box was broken before I temped to tell my wife I can't fix it so she won't ride with me lol
