Blue seat belts
Trader history (0)
Blakgeesus1
47
These were not needed.
Front retractable
Rear complete
$25
Mississippi
is that 2 shoulder belts (front seat), 2 lap belts (rear seat), and the matching buckle clips for both? (you indicate only the receiving clips for the rear)
look to be in good shape and color
Yes. I believe 3 seat belts for the rear.
ok, if I have this correct, 3 buckles for the rear, 2 retractable laps, 1 manual lap, (circled in Yellow) and then the 2 fronts with no matching buckles (circled in Blue)?
I'm assuming the fronts would work in an El Camino? and they do retract properly?
Everything circled is correct. Retractable for front should work as long as you're buckles are alike.
There are at least 2 different buckle setups, I believe there are standard and deluxe versions
Reactions: Blakgeesus1
wow! never seen that diagram before. I suspected that would be the difference. I'll have to go examine mine and be sure which ones I have. that will take a few days but definitely interested.
this is the spare tire buckle in my '82 Caballero flood project
this is the drivers clip from my 86
Hey, an extra seat belt for when you're tired.
