1978-1987 GM G-Body Rear Control Arm Reinforcement Braces
RB003
Launching harder, reducing wheel hop, and adding cornering consistency to your 1978-1987 GM G-body is easy with Control Arm Reinforcement Braces from BMR Suspension. Stamped steel sections of the factory frame can deflect under load and change the rearend geometry. BMR’s Control Arm Reinforcement Braces (RB003) attach to the inner upper and lower control arm mounts, adding strength to the areas that are prone to deflection. Manufactured from heavy-duty 1.00-inch diameter, 0.156-inch wall DOM steel tubing, with a center adjuster, the reinforcement braces are a great way to reduce frame deflection. BMR Suspension designed its Control Arm Reinforcement Braces to work well in street performance, drag race, and road race applications. The heavy-duty construction eliminates flex, giving you much improved repeatability on the street, starting line, or in the corners. BMR Suspension’s Rear Suspension Kits are available in black hammertone and red powdercoat for long-lasting good looks. Installation time is about 2-3 hours. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
