Body filler Qs- Help!
joesregalproject said:
Fox80 said:
Epoxy primer is what is called for in ICAR and ASE under the filler and in between coats, if your not done sanding I use spray can gray primer, that is just lacquer primer but as long as you sand it all off before you final prep it you will be fine.
I've been using a 1K rattle can primer from transtar, the guy who is painting the car (professional body man w/ 45 years experience) said it would be fine to spray my regular paint over top of it.
That is a very nice product, so yes I agree with him
I spray a quick, sloppy coat of that primer about noon today over the two areas I'm working on so I should be okay. The one area still needs a second cost of filler but it will probably have to sit as-is for a week or so until we get some warmer weather. Thanks guys.
