body level
jeremyandthemonte
731
150
hey guys i am wondering how do i check to see if the body is level on the frame? i had to use some more washers at the rear of the frame because of the aftermarket frame rails so i want to know if they are level with rest of the body
The rear of the frame is so flimsy, it's really hard to tell if it's level or not. Once you bolt the frame back to the body, you should be fine. I had to jack my frame up to get the bolts back in.
If you had to use washers that will mean your back bumper will be on an angle.
