87 Cutlass Supreme 442 Vin: 9 all stock
Checked fuel lines, put in new fuel pump, new fuel filter, had air compression check, there are no vacuum leaks, no cracked heads. I feel as if I have checked all except the carb. Before I get a rebuild or a new carb are there any other things that could cause the car to bog? Seems like a fuel delivery problem to me. It also has a real cold crank. Also, what would be the best carb to get for this 307 if I did have to get one?
Help, im twenty one, trying to learn as much as possible!!!
