Is there such a thing as a BOP Saginaw bell housing for a g body? I'm looking at the 4 speed route with my Regal and I can't seem to find a ton of info on manual trans g bodies without Chevy engines. Any insight?
Sucks that you didn't go with the 455. Just a stock rebuild of one to 1970 stage 1 specs gets like 400hp and over 500ftlbs, plus it weighs as much as a SBC. But BOP stuff sure is expensive.I have a 441 bellhousing, plus another BOP bellhousing from the 1970s. Side-by-side they look the same, and the 70's cars often had 11" clutches, so I suggest that if you can find the bigger 168-tooth flywheel, you could make it work. I don't have an extra curved G-body fork, but they can be had on http://www.4speedconversions.com. I had a brief moment when I thought I'd put a Buick 455 in a G-body, and then I got an estimate of the rebuild cost and decided to go with a 350 Chevy.
