If it wont I have access to a TH400 case. I should be able to swap the internals while upgrading with a shift kit correct? They should be he same internal just the bolt pattern for the engines will be different????? Anyone? :?: :?: :?:
Top 2 bolts (near distributor) are different between a Chevy and BOP. To use a BOP trans behind a Chevy engine (and vice versa) either get an adapter plate or use the correct case. Internals are the same. Gregg
