Boxed Lower Control arms
Yav8
287
137
79
Manitowoc wis.
Broke the rear sway bar and took the pieces off for the weekend. Car left nice and straight with not a lot of body roll. So the question is what is the easy way to box the lower arms. I was told that a piece of square tubing pushed up inside the arms and bolted tight works just as well as a full on welded control arm. Ideas and suggestions are welcome only if you have already done the work you are talking about. This means the magazine readers and the key board racers need not reply.
Just because someone may not have boxed their lowers or put a square channel in the control arm doesn't men they may not have some useful info. I have never seen anyone in here mention the square tubing so how about you do it and let us know how it works
Reactions: dlo253
The stock control arms are designed to flex to avoid suspension bind and snap oversteer. Boxing them up only make the rubber bushings distort more and even twist the LCA frame mounts. If you box them then you will need to install spherical bushings on one side of the arms.
please tell me how they twist when a sway bar is installed? The uppers are designed to twist. .. :roll:
