any time the light on the dash comes on,it is because you have a problem with the fluid side....the valve that has the wire on it has moved to stop you from losing all the fluid... the problem with the valve moving is you have to repair the problem and then bleed the brakes...... now if the rear side was the problem, the first thing to do is have a buddy push as hard as he can and open the front side so the valve can reset....take your cover off and open all the bleeder's and wait ..close the ones that start driping one at a time... after that pump your pedal and see what ya got....jesse
