Ok...so I had carb issues which caused me to have to tow the car home with a tow rope...just a mile or so, but without the motor running, the brakes were all but gone! I nearly ran into the guy pulling me with the truck. Anyway, after fixing the carb issue (stuck power valve), I noticed my brakes were still hard, like I had no power booster. So, I checked the valve, checked for vacuum and decided the problem was the power brake booster. And since I was at it, I bought a new master cylinder too. Replaced both...no help. Then I read that sticking wheel cylinders can cause a hard pedal, so I rebuilt the rear brakes, replaced all the hardware and the cylinders, shoes etc....still no help! So I bleed the whole system once more, and still having strange behavior. The brakes work fine sometimes, but if I pump them several times as I am driving, the pedal gets hard and the brakes dont seem to grab. I replace the calipers about a yr ago and the car hasnt been driven or outdoors much at all since then. I noticed the old master cylinder had a lot of dirt in the reservoir. Is it possible the calipers are sticking? When the brakes are working, the car stops well, no lockup and no pulling to one side... I feel like it could also be a vacuum issue to the booster. I tested the port and Im getting good vacuum to the booster at idle. Cant tell what it is at speed, but the issue seems more pronounced when Im coasting and moving slowly (under 30).
Any ideas? Im usually pretty good when it comes to brakes, but this problem has me really frustrated. Spent the whole weekend and today working on this...and I still feel like Im not getting anywhere. Thanks in advance for the ideas, thoughts, suggestions......
Bill
Bill
