I didn't have to push the pin in, it went back in on it's own when I was slamming on the brakes going in reverse. I use speed bleeders and nothing was coming out the back so I was just trying anything to get the valve back in position.
I found this online....I guess what I did equalised the pressure
The blocked side will trickle fluid out when the bleeder screw is cracked and the pedal pressed. An unblocked line will squirt fluid out the bleeder.
The lines that are clear must be left open and the blocked lines should have the bleeder screws tight to cause pressure to build up on that side. Be sure to use the standard bleeding procedures to prevent air from entering the system.
Slowly press the pedal with steady pressure a number of times until the light goes out; this will center the differential valve. You may also hear a pop come from the proportioning valve. This is the metering valve returning to its equalized position. When the light goes out, close the bleeder screw.
