When you say SS brake lines do you mean you replaced the rubber hoses with SS or do you mean all the hard lines ?
If you replaced the hard lines you might have a leak that you just havent found and its sucking in air. I just went through this with my 81 Malibu. The line from the master to the proportioning valve was seeping fluid at the line under pressure. Not enough to drip on the floor but with pressure on the pedal the tubing was wet at the fitting. Tightened it up and it started leaking at the threads. It was a pain in the butt to get that one line to seat.
I checked all the lines multiple times before I found that. If you have the calipers in right, your rear brakes adjusted, and it wasnt like that before, theres something youve missed and its something simple.
