Brake rattle
Dylan88
164
23
36
Hey hows it going? Quick question maybe you guys will know.
Noticed a rattle sound coming from front end near the brakes or when i hit the brakes long story short noticed the front pads move quite abit and are probably rattling. So i bought new anti rattle clips. Is it just 1 clip per side of car? The box just had 2 clips so was curious . Anything else to check?
Think about it: if you're on the brakes, the calipers are pushing the pads into the rotor and the friction/centrifugal force is pushing the pad to the front of the caliper grooves (that the pads ride in). How could it possibly move enough to make noise? Are the rotors warped? Is it a jingly sound (sway bar end links)?
I know Just when you first hit the brakes after that is fine. Not while your braking and front end is all new. Rattles over large bumps too
