I love the L69 air cleaner housing and run one myself. The important thing to remember is that each snorkel by itself is larger than the one snorkel on a standard single snorkel housing. Another thing you can do is run the lid off a G body Monte Carlo which permits a taller filter element. This is the setup I run, but I have not figured out how I am going to run the ram air setup in my car yet. Oh, one more thing: The A/C brackets are different as is the hose set fromt he compressor on a L69 Camaro as opposed to a LG4 Camaro. I run the brackets and hose from the Camaro with the Condenser from a L69 car as well. The small aluminum tube from the evaporator to the condenser has a fitting in it in a Camaro and must be used as well. Mine is from a TPI car. I also used the V6 Cutlass Dryer with my setup as it let me fit the hoses together properly. The larger hose on mine differs from stock Camaro in that the stocker has a 45 degree downward bend, but the aftermarket one I used has a straight fitting which worked better in my application.
