Broken Exhaust Manifold Bolt
Building weld up on the broken bolt is easy. I highly recommend this method. Make sure you protect the head from weld splatter and you will be OK. As you can see in the pic below I used a harbour fright flux wire welder and duct tape which worked OK. I had 3 broken bolts on the 5.3 heads that came out easy with a vise grip.
I've had the same thing happen to me. I was lucky it was on a 5A (307) head and it was a "through bolt" hole. Just drilled it all the way through and then used MAPP torch to heat up the head area around it and it eazy outed right out. I still think I was lucky.
Olds heads suck when they eat your bolt.
Anyway, glad to see you here! How you feeling lately?
I'm off the narcotics and I'm healing as expected. On Friday I meet with the oncologist to review their latest pathology report. I am hoping an praying that there will be a suitable treatment option. Thanks for asking.
i hope everything goes good for you Anubis.
With the broken bolt which one is broken KAP makes kits for broken exhaust manifold studs. I too broke an easy out in one and used the KAP plate and i have no leaks
And that's why I didn't do my header installation..
11 out of 12 snapped off... they did all 12 with helicoils. (Cost just a lil extra)
-Gonz
You may be able to drill it out, but chances are you will eat up a lot of drill bits since the stud is actually harder than the manifold it's broken off into. I worked at a Midas for years and I've had this problem hundreds if not thousands of times. Your 3 easiest options, either find another manifold with good or no studs, leave it in and find a thing called "clamp a stud" it looks like a baby c-clamp and allows you to use the top part to slip over the manifold with the broken stud where it is, then you tighten the threaded rod against your flange, they actually work great, or find a reputable exhaust shop with acetylene torches and someone confident that they can just "blow the old stud out" without damaging the threads in the manifold and pay them $20-30 bucks to do it (it can be done)
