Given the choice of cheap full size 4x4 SUV's of the 1980's that are available for less than $1500, which would you choose? The full size OJ Simpson style Bronco, with the split axle front end and a 302 or 351W in it, The 1973-87 Chevy K5 Blazer 4x4 with either a 350 or 305 in it, and twin solid axles, or a Dodge Ramcharger with a 318 or 360 and solid axles? The Chevy and Dodge both use Semi-Elliptic leaf springs front and rear, and have manual hubs on some years, as well as 2 speed gear selected transfer cases, while the Ford uses the split axle front end on coil springs with leaves out back. The Bronco is more expensive to lift than the other two, but seems to be more plentiful at a low cost. It also has some years with electronic transfer cases, which may not be a good thing. The Dodge is reputed to have the best axles of the three during the 80's with a Dana 44 front and Mopar 9.5 out back. It also came with the Torqueflite 727 transmission which is pretty strong too. The Dodge, though did not have a removable roof in the 80's, while the Chevy and Ford did. The Chevy had a TH 700 R4 transmission in it, which can be crap in this application without modification, and the axles may or may not be good depending on the year. So, given a choice for a fun, cheap truck to go do some moderate off roading without spending too much money, what would you buy? I will also throw in the full size Jeep Wagoneer/Cherokee as an option as they tend to be available cheap and were also full size truck based during these years. Power in them was usually an AMC 360 with a TH 400 transmission and a variety of part and full time transfer cases.
Emphasis in this would be on the one that is the best right out of the box, without major changes in hardware and equipment. (This is another thing I am considering getting in to with the money from when I sell off my AMC Spirit project that I don't want anymore)
