I saw the cheap drop spindle option. Amazon.ca has a set that work out to under $300 CAD to my door. Summit has some that work out to a little more than that. I'm not sure if there's anything cheaper than that without buying a seacan full of them from China. Guys also seem to be pretty horny about the taller lower balljoint, which is something I know nothing about, other than I guess it will help a little with giving you some camber. Do I care? Probably not.
When you cut/use an open ended spring for the rear, are you cutting the top or the bottom? And if so, are you doing anything about the coil bucket/isolator being wrong for a spring like that, or just ramming it in there and not giving a fawk? I could just pull the rear end out of the car and rework the coil buckets to accept a normal open ended configuration, in fact I'm sure I have a set of half made buckets lying around from a Jeep. I don't want to do this though, as I was hoping to do something quick and dirty.
I'm in PG. It's not remote, it's "somewhat remote", in that to drive to the great big bald eagle in the south it will take you a whole day one way. There also isn't much good used stuff around here, population density level is low, poverty level is high.
Edit, also I looked through the first 8 or so pages of your build thread. Very nice. I'll have to read the rest of it when I get a chance.
