Hey, Just wanted to drop you guys a note on what I found on these headers from Jegs.
Part number : 555-30060 made in usa
They were listed as compatible with 85 monte carlo 350 / automatic /column shift or floor shift. No manual.
I figured I can't go wrong here. Less than $120 for the painted version , got headers and did a test fit.
The driver side rear tube #7 cyl. Was so wide off the flange it was right in the column shift linkage. Took 3 hours
to modify the linkage so the transmission would go into all gears. Without mod only park, reverse, neutral could be engaged.
all of the tubes on 1,3,5 cyl were dead on in line. # 7 stuck out about 2" further for no reason what so ever.
OK now the passenger side, Even the fit was better it still had the same issue with the #8 cyl tube sticking way out past
the other tubes on 2,4,6 cyl. Luckily there is a gapping hole under the firewall for this.
why these were made like this is beyond me. I understand equal length and that, But I even called to company and asked
them about fitment of this product. I was told they don'y just throw them together- they are designed to fit !
Well they were about 5 hours and 30 curse words away from being correct. I did get them in and they will work now.
However they are being sold as a WILL FIT 78-87 G body 265-400 SBC column or floor shift automatic.
I sent them photo's of the (it hits here ) in hope that they fix it for others who may get the nod to buy these.
careful !!!
jake 87BlazeLS
careful !!!
jake 87BlazeLS
