Hi. I'm new to the group. I have an 85 caballero. I need a frame. Got a 86 GP frame, was told any gbody frame would fit but it don't. Do anyone have one for sale. I have to get rid of the one I have is there's nothing I can do with it
Might help if state were u are located.. elco frames are longer than other g bodies. What is wrong with yours? Good luck on your search.[/QUO
I'm in St.Louis Mo. Mine is bent pretty bad right by the wheel and good luck is the last thing I'm having. Thanks for replyingMight help if state were u are located.. elco frames are longer than other g bodies. What is wrong with yours? Good luck on your search.
I have a spare elco frame. If your can weld or get it welded I can cut out the peice u need.. do you have pics?
No I dont. I can get one tomorrow. I'm in st.Louis MO. I was thinking that I could cut and weld. It's damaged in the front. I was thinking I could but the back off my old fame and use the front of the new frame. I don't know. My car and both frames are at a shop. Now they're still charging me for labor and I have to get everything from there. I would rather figure something out, otherwise that's all money I blew for nothing. Back to square one with almost $2000 goneI have a spare elco frame. If your can weld or get it welded I can cut out the peice u need.. do you have pics?
