81 Caballero door
81 Caballero
14
4
Hey guys! So I have a problem with my driver side door closing correctly. I don’t see a sag, but when I close it, it seems like it’s not griping the striker. I have to slam the door pretty hard for it to actually close tight. Do I need a new striker, because I’ve bought some before and that didn’t seem to work if I remember correctly.
Thanks
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,178
9,779
Gainesville, Fl
Have you tried to adjust it..up down side to side. Also, what condition is your hinge pins and bushings in? You said the door doesn't sag.
I guess it's easy enough to determine if the striker pin has significant wear. I'd still try to adjust it first and apply some grease to the pin and latch.
81 Caballero
14
4
The hinges seem fine. You mean adjust the striker up and down?
Longroof79
Oct 14, 2008
12,178
9,779
Gainesville, Fl
melloelky
4,166
9,583
mass
Thanks
Jack's on the rite track with the striker position might need some attention.
roll the window down and close the door see if the amount of resistance changes.a lot of times with these frameless window designs a missadjusted window will push back on you and it can feel like a door fitment.
Ribbedroof
4,907
7,025
Wellston, OK
Are you sure there's no sag at the hinges? Because strikers don't really move unless messed with.
Open door fully. try to pick up door at the back end. If it moves at all (up/down) you've got pin /bushing problems
These doors are HEAVY and hard on pins/bushings, especially since the general public never lubes them
Pic of striker, and vehicle with door closed would help diagnosis
Every G body I've ever bought needed pins/bushings, even the one that was 9 years old
Reactions: 6 users
