I am looking at a Comp Cams Hi-energy cam (42-221-4) or a Voodoo (256/262) cam from Lunati. Can either of these cams be used with the stock (non-adjustable) rockers and pushrods? If not, then what is the cheapest way to make a better cam work with a 69 Olds 350? The last engine that I built, I used roller tip rockers from a big block Ford (I think...it was 10 odd years ago...) which worked well. Open to suggestions or comments. Looking for 300 to 350hp from the engine in a most day driven street car with occasional track use, so nothing huge... transmission will be a turbo 350 for now until I can find a decent 200-4r to swap in.
