So my car has been doing something weird, but now it seems to be becoming more frequent. At about half throttle when you are getting up to speed, only in 3rd gear and at 2500 rpm, it will suddenly act like it is going to downshift, and slow the car way down. If you get off the throttle real quick and get back on it, it will continue to accelerate normally. If you don't take your foot out of it, and give it more throttle, the rpm will just shoot up. Cables are adjusted correctly, and fluid is always full (doesn't really use any fluid.) Doesn't matter if the car is hot or cold. And it won't happen if you give it any more/less then half throttle. We have to pull the pan off to put a TCI lock-up kit in, so I guess then we can do some inspection. I'm thinking there might be something hung up in the valve body. Any ideas?
