Few questions for the pros....
#1. I have debated this many times. Some people say to put tweeters up on the dash, pillar or upper door panel and put the speaker in the lower part of the door.
I always say, and others have said also that the tweeter should be no more than a foot from the component speaker for proper imaging.
What is your thought on this?
#2. When installing subs in a G-body, what is the best way to mount the Subs? Looking for both ported and sealed enclosure ideas. I see some face the trunk with ports going up through the package tray as well as facing the back of the seat. Base is non-directional, correct?
#3. When it comes to an ultimate sound system, rear speakers are really not needed unless you are doing a DVD 5.1 surround sound setup.
So If I buy a pair or Focal components for $600 and get a cheaper pair of coaxial speakers for the rear, set the fade to mostly to the front with just a little rear fill, everything would be OK????????
Just getting ideas together and planing out a system for when I have the money.
