Running hot, oily, and rich I would suspect the float setting or float needle. That's another problem with the alcohol gas, it eats the plastic float. I only use brass now and knock knock no more float issues.
"Well there's your problem" Look at the accelerator pump.rIbBaD said:I have a factory 4 barrel carb, I got it professionally rebuilt about a year and a half ago, however after I got it rebuilt it sat for a year and a half until I started driving it again 3 weeks ago.
Spraying carb cleaner into the throat and choke valve and air horn has saved me a couple times from having to rebuild my carb so it does work for me. Like i said in my first post, check the accelerator pump like everybody else has said. If it's not a new accelerator pump valve that is resistant to ethanol you need to change it with a new one.RITTER said:No, you have clean the inside of the carburetor. The top plate has to be removed and the jets need cleaned along with the needle & seat. Just spraying carburetor cleaner down the carburetor doesn't do anything. You will need fine point picks and needles to clean out the small holes inside the carburetor :idea:
